issue with custom cronjobs and scripts
thisismosi
thisismosi Posts: 3
edited May 2023 in Personal Cloud Storage
Hello there
I have an NSA325 v2 I connect to it using ssh and try to set up my custom cronjob and run my custom scripts.
after any reboot, the whole cronjobs and script get removed and I don't know why it's happening! is it something about the Linux version?
is there any way to install something like Debian or red hat on NSA325 v2?
regards
  • Mijzelf
    Mijzelf Posts: 2,911  Guru Member
    The problem is that the /etc directory in in the initramfs (with exception of /etc/zyxel, on which a flash partition is mounted), and so any change won't survive a reboot.
    I wrote a package 'Tweaks', which can add cronjobs (an other goodies), which you can install if you first install MetaRepository.
    Yes.
  • antren
    antren Posts: 1
    it is possible that the firmware is configured to reset the system to its default state upon reboot. You can try creating a startup script that sets up your custom cronjobs and runs your custom scripts after the system boots up.
