NSA540 - https lockout
Hi. I created a self-signed ssl cert within the Zyxel UI, and imported to my browser.
The certificate fails - Connection Refused.
Unfortunately I aslo selected the HTTPS ONLY option so cannot use http
I have look at httpd.conf via SSH, cannot find the lines to enabling listening on port 80, or disable any re-directs. cannot find any .htaccess file either.
Can anyone adivse which file/s I edit and how?
I do nto wna to factory reset the NAS>
Many thanks for any ideas.
Cheers Franklin
NSA540 running LMS Squeeze
Most configuration is stored on a flash partition which is mounted on /etc/zyxel/. (Factory reset is mainly erasing this partition). I think the redirect is stored in /etc/zyxel/conf/startup-config.conf.xml , between the tags <redirect></redirect>. On my system there is a 'no' there. If yours has a 'yes', change it, do a 'sync' (don't know if that is needed, but it won't hurt) and reboot.
- 220 Nebula Ideas
- 607 USG FLEX H Series
- 299 Service & License
- 482 News and Release
