Important Zyxel Resource is Down
NEP
NEP Posts: 79  Ally Member
I was trying to set up an L2TP VPN today and when I clicked on "Configuration Walkthrough" it popped up a dead page (url listed below).https://kb.zyxel.com/KB/searchArticle!viewBlob.action?attOid=14441
I checked with a third-party site to see if it was just us and it wasn't. Also, according to MX Toolbox, there is no DNS record for "kb.zyxel.com". As such, everything that links to this subdomain is not working.
Are you aware of this issue? Is there an ETA on fixing it? Thanks.
  • Zyxel_Cooldia
    Zyxel_Cooldia Posts: 1,537  Zyxel Employee
    Hi @NEP ,
    What is your model name and firmware version?
  • NEP
    ATP800 running "V5.35(ABIQ.0)ITS-23WK06-r107740 / 2023-02-04 03:20:27".
    Should be the latest, prior to the one released at the end of April. It's a weekly build that we updated to because the last stable release had a bug that was flooding our logs.
    Not sure why the links would have changed between versions or if they did why the prior domain was taken offline so quick, but is there a way to access that link with an updated URL?
  • [Deleted User]
    [Deleted User] Posts: 3  Freshman Member
    First Answer First Comment Friend Collector Third Anniversary
    Hi @NEP,
    If you want to get a really good article about setting up L2TP, please check out this one:
    It never fails me.
    Hope that helps!
  • NEP
    Thanks @AndreasZyxel. That is the page I was looking at prior to attempting "Configuration Walkthrough". It shows set up for IKEv1 and I was looking to do IKEv2 as the other is old and considered insecure. Can't imagine the process is too different. Just looking for a little extra info, hence the config tool. Thank you though.
  • NEP
    @Zyxel_Cooldia Thanks for that. Will look into it that shortly. However, that doesn't answer my original question. The kb.zyxel.com website still appears to not working. Any news on it being fixed?
  • NEP
    @Zyxel_Cooldia Is there any update on this?
  • NEP
    edited May 2023
    @Zyxel_Cooldia Just got around to checking this again. I see that the links no longer appear to point to that subdomain. Also, I was able to get an IKEv2 VPN set up with the information that you provided. Thank you!
  • byerh
    byerh Posts: 2  Freshman Member
    I have a similar issue:
    I have a ZyWall 110 running the latest firmware as of 10/10/2014.
    Help links and configuration links no longer work from the Admin Web GUI.
    The popup pages indicate "The site can't be reached". Anything pointing to kb.zyxel.com no longer works. It is not a browser issue. This is 100% a Zyxel issue. When will it be corrected please.
  • Zyxel_Melen
    Zyxel_Melen Posts: 3,529  Zyxel Employee
    Hi @byerh,
    The firmware version of your ZyWALL110 seems not the latest version. Please find the latest firmware on EOL page since it is an EOL device.
    End of life | Zyxel
    I check the help link is available on this firmware version.
    Zyxel Melen
