Adding Syncthing to Zyxel NAS540
ssmith369
ssmith369 Posts: 6
image  Freshman Member
Good morning
I am trying to add Syncthing to my Zyxel NAS540. I have read a few posts and managed to install the Mijzelf Reposistory. This has installed some useful apps like Total Commander and Plex Media Server, but it doesn't install Syncthing. I am guessing it used to?
Can anyone help with installing Syncthing? I have just built an Unraid server and Syncthing would be the perfect package to sync my NAS to the Unraid server.
One other question, I have installed Total Commander, but it doesn't do anything when I click launch? Any ideas?
Any help would be very appreciated.
Many thanks
SS
  • ssmith369
    ssmith369 Posts: 6
    Many thanks for the reply.
    Perfect. I should have checked to see if it used to be called something else!!
    I did wonder whether Total Commander was command line. Thank you for clarifying.
    I guess I need to manly update syncthing to 0.13 before I can get the web GUI update to work? I think I read about that elsewhere?
    Many thanks again
    SS
  • Mijzelf
    Mijzelf Posts: 3,074
    image  Guru Member
    The Syncthing package is called Pulse. That was the name of the tool at the moment I created the package.
    MidnightCommander is a commandline tool. So to use it you'll have to use an ssh or telnet shell.
  • ssmith369
    ssmith369 Posts: 6
    Many thanks again
    SS
  • ssmith369
    ssmith369 Posts: 6
    I have v 0.12.4 installed. I am guessing this is too old a version to talk with my Unraid server which is running v1.23.4 as I get this message:
    I obviously would like to upgrade syncthing on my NAS anyway. I am following this artcle:
    h**ps://forum.syncthing.net/t/update-of-syncthing-on-nas-zyxel-nsa325-v2/14676
    which says you have to manually change the bin from the download to v 0.13.1 then the web GUI upgrade will work.
    It also states that the syncthing bin is in /usr/local/zy-pkgs/bin. I don't have this folder at all. My syncthing binary is in /i-data/c8c5d1df/.PKG/Pulse/bin.
    I stopped syncthing, renamed the exisiting binary, copied the v0.13.1 binary to this folder then changed it's attributes to 755.
    When I restart syncthing I get this:
    The first odd thing is the "(unknown device)" instaed of "NAS542" top left. I thought, not a problem, I will just go into Actions>Settings and change it. But If I click Action>Settings, I don't get a settings GUI nothing happens? So I then try and click the weird "Upgrade To {%version%} button. This does actually upgrade, but when it restarts, I just get a blank web GUI with just this at the bottom:
    I do get a new binary file after the upgrade:
    What am I doing wrong? I am suspicious of the bin location, but my knowledge of Linux is limited.
    Any help would be much appreacited.
    Many thanks
    SS
  • Mijzelf
    image  Guru Member
    Have a look in the admin share. There should be a directory 'Pulse', which is the home directory of Syncthing. According to the startscript there should be a logfile there, and Syncthing stores it's settings there. Maybe the settings file is incompatible. Disable Syncthing, delete the settings file, and start it again.
  • ssmith369
    ssmith369 Posts: 6
    Sorry for posting this on a seperate post. I didn't think the above posted yesterday.
    It appear that the problem was just a browser cache issue. Once I did the upgrade to the newest version, I tried http://NAS542:9999 in a different browser and it all works great. The unraid server and NAS542 are syncing as I type :-)
    Many thanks for your help
    SS
