Problem upgrading Syncthing on NAS542
I have v 0.12.4 installed. I am guessing this is too old a version to talk with my Unraid server which is running v1.23.4 as I get this message:
I obviously would like to upgrade syncthing on my NAS anyway. I am following this artcle:
h**ps://forum.syncthing.net/t/update-of-syncthing-on-nas-zyxel-nsa325-v2/14676
which says you have to manually change the bin from the download to v 0.13.1 then the web GUI upgrade will work.
It also states that the syncthing bin is in /usr/local/zy-pkgs/bin. I don't have this folder at all. My syncthing binary is in /i-data/c8c5d1df/.PKG/Pulse/bin.
I stopped syncthing, renamed the exisiting binary, copied the v0.13.1 binary to this folder then changed it's attributes to 755.
When I restart syncthing I get this:
The first odd thing is the "(unknown device)" instaed of "NAS542" top left. I thought, not a problem, I will just go into Actions>Settings and change it. But If I click Action>Settings, I don't get a settings GUI nothing happens? So I then try and click the weird "Upgrade To {%version%} button. This does actually upgrade, but when it restarts, I just get a blank web GUI with just this at the bottom:
I do get a new binary file after the upgrade:
What am I doing wrong? I am suspicious of the bin location, but my knowledge of Linux is limited.
Any help would be much appreciated.
Many thanks
SS
Please ignore. Asked and answered on another post.
SS
SS
- 438 Beta Program
- 189 Nebula Ideas
- 6.2K Security
- 463 USG FLEX H Series
- 304 Security Ideas
- 81 Switch Ideas
- 280 Service & License
- 439 News and Release
- 4.3K FAQ
- 91 Security Highlight
