NAS326 Is it normal for the disk1 LED to blink every +-4 seconds?
cobraninja
cobraninja Posts: 1 image  Freshman Member
I just have one disk installed, WD Red Plus, just added a file to test it, no app installed, and the disk1 Led light blinks every +- 4seconds, at night this behavior becomes noisy each time it blinks it seems the disk makes a noise like accessing it.
Does someone knows if this is normal?
  • Mijzelf
    Mijzelf Posts: 3,042 image  Guru Member
    No, that is not normal. I don't know about the LED, but the "disk makes a noise like accessing it" should not happen. The disks are supposed to be able to sleep, when the NAS is idle.
    I vaguely remember that the LED's on the 5xx blinked slowly when the disks were asleep, but in that case the box was silent.
    Have a look in the status screen if some process is active, when the box should be idle.
