18TB on NAS326 as JBOD
I've just bought a NAS326 and (sadly) a 18TB hdd. I want to install it as jbod. I'm OK on wasting 400gb of space. The web interface doesn't let me format only 16TiB. If I select "Single volume on RAID" it tells me that it is too big. Can I do it manually? I know how to use SSH, but when I tried to format the hdd in ext4 "manually", the NAS326 didn't recognize it.
What do you mean? It can create a 16TiB volume, but not as single volume on RAID?
Yes. If I try to:
then
But then
There is no option to reduce the partition size to 16 TiB.
If I go through the
it works, but I'm interested in the "better access performance"
Ah, I see.
For the record, I don't think you'll notice the difference.
I think you can create a disk group, and then from the command line just put an ext4 filesystem on the raw raid array. The 16TiB limitation is because ext4 originally had a limitation of 2^32 clusters. The limitation was lifted around kernel 3.2. Your box runs 3.10, so the kernel should support >16TiB. Don't know if mke2fs also supports that. Your original attempt to put ext4 on the disk was on the box?
To be able to put a filesystem on the raid array you'll first have to umount the volume(s) and maybe remove the logical volumes with lv/vgremove. That can be hard, as the firmware has internal bindmounts on the volume, and running processes which keep some files open. But there is a work-around, you can inject some code in the shutdown script to get shell access after the firmware has cleaned up it's mess. Search the forum for resize2fs, and on a NAS, not an NSA, which is slightly different.
When the volumegroup is gone, and an ext4 filesystem is put in it's place, I expect the firmware to use that, after a reboot.
- 588 USG FLEX H Series
- 477 News and Release
