GS1915 VLAN Not Showing in Nebula Cloud
aduw1ng
aduw1ng Posts: 2
edited May 2023 in Nebula
I configured some VLANS on the GS1915 switch using the web configurator and connected it to the Nebula Cloud Center. I noticed the VLANs I created are not showing up in NCC. Is this an expected behavior?
  • Zyxel_Melen
    Zyxel_Melen Posts: 3,559  Zyxel Employee
    Hi @aduw1ng,
    Could you share a screenshot about which VLAN did you created and enable Zyxel support for me to check?
    Please go to Help (On the top right) > Support Request > Zyxel support Access to enable and save.
    Zyxel Melen
  • Zyxel_Melen
    Hi @aduw1ng,
    The VLAN configuration which is set on the local web GUI won't sync to Nebula. I recommend configuring it on Nebula.
    Zyxel Melen
Nebula Tips & Tricks
