XMG3927-B50A firmware version
My Zyxel XMG3927-B50A is currently running with its stock firmware V5.13(ABQO.0)D0. I have noticed that a new firmware is now available as V5.17(ABMT.5)C0.
Will this firmware work for my device despite the different strings ((ABQO.0)D0 vs. (ABMT.5)C0) ?
-Joel
Hey Joel,I update my firmware come from Swisscom (Switzerland) to the factory one this weekend because I needed to use mPro Mesh solutions from Zyxel.Base firmware branded : V5.13(ABQO.0)D0.Updated firmware : V5.17(ABMT.5)C0.Please watch this video to help you : https://youtu.be/vHDUjFk9u1MSTEP 1 : Use Terminal (MacOs) or PuTTYssh (ip router) -l (username)My exemple with Terminal : ssh 192.168.1.1 -l adminSTEP 2 : Follow these commands when connectedzyclizycli modelcheckzycli modelcheck show (Result : "ret:0")zycli modelcheck offzycli modelcheck show (Result : "ret:-17")zycli fwidcheck show (Result : "ret:0")zycli fwidcheck offzycli fwidcheck show (Result : "ret:-17")exitSTEP 3 : Update your firmware with the web interfaceEnjoy1
(ABQO.0)D0 and (ABMT.5)C0 are different firmware versions for XMG3927-B50A.
It can't be loaded with different firmware versions.
Im trying to do this on a locked down
KCOM
isp router ZYXEL version XMG3927-B50A but when I get to putty its either freezing or times out.When I try to do it on my own ZYXEL XMG3927-B50A it works any idea as want to update and change the locked down firmware on the KCOM modem
It looks like your SSH port is closed. Can you check in the web UI under "Maintenance → Remote management"?
well had a look only HTTP and HTTPS open nothing else in. On my own other (same model modem/router) it has loads of stuff in SSH being one of them.
I tried making a non admin account but stil the same……………its locked down to the isp config
If your version is below V5.15(ABMT.5)C0, you should be able to use this:
Obviously, don't do this unless you actually own the device.
Good luck
2 -
yes I have the modem still, but it looks a nightmare (after reading all that link) I`ve managed to buy another 2nd hand (same model) this one IS unlocked and even has the Firmware installed that I want (so all ok) I`m trying to get my money back for this locked unit as was it sold as locked and I was not told this.
But thanks for the info maybe one day when bored and is raining outside I might (if still stuck with it ;-) give this ago whats on your link.
Many thanks
I got an other spare/second hand XMG3927-B50A yesterday it had the same firmware as mine but I flashed it again and it worked ok so on v5.17 (ABMT.6)C0 same as mine then update/copied over the same setting seems to work OK. I will test it out live when kids in school Monday but looks ok and a good back up to have incase mine packs in
connected it all up this 2nd hand XMG3927-B50A and works a treat, good 2nd hand buy that works like my original :-)
- 439 Beta Program
- 2.8K Nebula
- 196 Nebula Ideas
- 6.3K Security
- 481 USG FLEX H Series
- 313 Security Ideas
- 83 Switch Ideas
- 45 Wireless Ideas
- 284 Service & License
- 450 News and Release
- 4.3K FAQ
- 93 Security Highlight
