NAS326 - transfer data to replacement HDD.
Hi all - my NAs326 fell onto the floor and the disk drives were degraded.
I have bought two new HDD and copied all the data onto onto one of the new HDD
When I put the new backup HDD and the empty one in the NAS it seems it wants me to create a Group and lose the data. ##How do I lkeep the data and set up a new Raid 1 system
Any help appreciated!!
thanks very helpful will give it a go!
If your old HDD has a RAID 1, you can follow these steps to replace the drives:
- Pull out one of the old HDD
- Insert one new HDD into the NAS and initiate the repair process through the NAS interface. This will pair the new HDD with the existing old HDD.
- Once the pairing is successful, remove the other old HDD from the NAS.
- Insert the second new HDD into the NAS and initiate the repair process again.
By following this procedure, you can replace the old HDDs with new ones in a RAID 1 configuration .
Can I replace different capacity HDDs, like from 2 of 4TB of Raid 1 to 2 of 8TB by this way, Thanks.
I would be interested in this one as well. I would like to migrate from a 2x3TB RAID1 to a 2x6TB RAID1. Can I just do it the way it is described above? Would it recognize the larger volume?
It is supposed to.
- 243 Nebula Ideas
- 6.9K Security
- 786 USG FLEX H Series
- 391 Security Ideas
- 88 Switch Ideas
- 58 Wireless Ideas
- 7.3K Consumer Product
- 325 Service & License
- 528 News and Release
- 102 Security Advisories
- 5.4K FAQ
- 91 About Community
- 122 Security Highlight
