NAS326 - transfer data to replacement HDD.
philr123
philr123 Posts: 4 image  Freshman Member
Hi all - my NAs326 fell onto the floor and the disk drives were degraded.
I have bought two new HDD and copied all the data onto onto one of the new HDD
When I put the new backup HDD and the empty one in the NAS it seems it wants me to create a Group and lose the data. ##How do I lkeep the data and set up a new Raid 1 system
Any help appreciated!!
  • philr123
    thanks very helpful will give it a go!
  • okimarukas
    okimarukas Posts: 92 image  Ally Member
    If your old HDD has a RAID 1, you can follow these steps to replace the drives:
    1. Pull out one of the old HDD
    2. Insert one new HDD into the NAS and initiate the repair process through the NAS interface. This will pair the new HDD with the existing old HDD.
    3. Once the pairing is successful, remove the other old HDD from the NAS.
    4. Insert the second new HDD into the NAS and initiate the repair process again.
    By following this procedure, you can replace the old HDDs with new ones in a RAID 1 configuration .
  • philr123
  • bylmy
    bylmy Posts: 1 image  Freshman Member
    Can I replace different capacity HDDs, like from 2 of 4TB of Raid 1 to 2 of 8TB by this way, Thanks.
  • tpolakov
    tpolakov Posts: 2 image  Freshman Member
    I would be interested in this one as well. I would like to migrate from a 2x3TB RAID1 to a 2x6TB RAID1. Can I just do it the way it is described above? Would it recognize the larger volume?
  • Mijzelf
    Mijzelf Posts: 3,049 image  Guru Member
    It is supposed to.
