NR5103E Flashed wrong firmware = bricked ?
hi all
I bought 5g router NR5103E and accidentally flashed V4.19(ABYC.3)C0 firmware made for NR5103
I bought it second hand so there’s no way I will get support from network provider Is there a way to restore right firmware and get it back to life ?
For now I’m able only to access setting via LAN. Wi-Fi is on but is not working cellular works as expected
I had idea to flash back right firmware but I’m unable to find files online. ( I have no backup to restore )
thanks
Hi @Yayabociana ,
Please check the inbox message, thanks!
Hi @Yayabociana ,
Please check the inbox message, it's checking the S/N ans see how can we help from here.
thank you !
I also faced the same problem can anyone help me
hi all
I had idea to flash back right firmware but I’m unable to find files online. ( I have no backup to restore )Can you help me
Did anyone have a solution for this? I'm in the same pityful situation. :-(
- 222 Nebula Ideas
- 617 USG FLEX H Series
- 53 Wireless Ideas
- 485 News and Release
