How to Docker on my NAS542?
Hello guys,
I am questioning myself, is it possible to run Docker on a Zyxel NAS542 and how difficult would it be to create a kernel?
This blog post gives me some nice information on how to check the kernel configuration for Docker when I am using an embedded device.
However, I am unsure of how to flash the kernel onto the device. Are there any scripts that I can use? Can someone give me some tips?
My goal is to install Paperless in Docker with OMV.
System info:
openmediavault 4.1.36-1 (Arrakis)
Kernel: 3.2.0-6-nas5xx
Architecture: armv7l
Byte Order: Little Endian
CPU(s): 2
On-line CPU(s) list: 0,1
Thread(s) per core: 1
Core(s) per socket: 2
Socket(s): 1
Model: 1
CPU max MHz: 1200000,0000
CPU min MHz: 160000,0000
BogoMIPS: 1196.85
Flags: swp half thumb fastmult vfp edsp neon vfpv3 tls
hi,
were you successful in your attempt to install Docker?
I would like to do the same on my Nas5420 -
Hi Sitro,No, it wasn't. I spent thousands of hours creating a kernel compatible with Docker, but it always ended up in a bootloop. Additionally, the hardware is too slow for these types of processes. I flashed it with an available .img from the internet that comes whit OpenMediaVault.
As a workaround for Docker, I decided to buy a Raspberry Pi 4 and install Docker on it along with Portainer and Paperless etc. I was able all to set it up in just a couple of hours. Then I backup the volumes with data using a custom backup script that I created for the Raspberry Pi and then upload them to this "NAS" device.
I don't think it's worth the time to attempt any hacks with the NAS, but if you want to try, it can be a good learning experience for your programming skills, flashing, and learning new Linux commands, etc.
- 439 Beta Program
- 2.8K Nebula
- 200 Nebula Ideas
- 6.3K Security
- 499 USG FLEX H Series
- 323 Security Ideas
- 49 Wireless Ideas
- 287 Service & License
- 457 News and Release
- 89 Security Advisories
- 4.3K FAQ
- 96 Security Highlight
