Official Repository for Zyxel NAS540 not working
SirLuckalot
SirLuckalot Posts: 2 image  Freshman Member
I am using the NAS540 and I'm struggling with the repositories. I'm using MetaRepository. I cant connect or find any OFFICIAL repository. Right now I am looking for the dropboxClient app to sync with dropbox and I cant find it anymore.
For now I am using just these working repos from Mijzelf:
https://metarepo.tk/Users/Mijzelf/zypkg-repo/NAS540/zypkg/5.21/
https://metarepo.tk/Users/Mijzelf/zypkg-repo/fw5/
and the official ones are not working anymore:
ftp://ftp.zyxeltech.de/NAS540/zypkg/5.20/
ftp://ftp2.zyxel.com/+ ZyXEL
Do you guys have an idea or a working official repo?
Thanks!
  • Mijzelf
    Mijzelf Posts: 3,020 image  Guru Member
    The zyxeltech.de mirror has been gone for years. The repo on ftp2.zyxel.com still exists, and contains 540 stuff. (ZyXEL has 6 months ago removed all EOL stuff, but the 540 is not among them. (Surprisingly enough the 520 is, although it's newer than the 540))
    It could be a DNS issue. Assuming you have the latest firmware the box tries to download ftp://ftp2.zyxel.com/NAS540/zypkg/5.21/ZYPKG_INFO.tgz
    You can login over ssh and try to download the file manually:
    wget ftp://ftp2.zyxel.com/NAS540/zypkg/5.21/ZYPKG_INFO.tgz
    If that fails, and the downloads from metarepo.tk don't, it's probably a DNS problem. There might be useful information in the logfile. (\\<NAS>\admin\zy-pkgs\ZYPKG_INFO.log)
  • Mijzelf
  • SirLuckalot
    Thank you!
    Surprisingly I was able to login with a FTP app now and I also am able to download the list now with the NAS.
    Maybe the servers were off or misconfigured at the weekend as I tried.
    Just to be curious (or safe): When I downloaded the tgz, where do I have to put it? And shall I also download all the packages I see now there just for my backup?
    Do i declare a local repository and put everything in that ftp path in it?
  • Mijzelf
    Nowhere. It was just a test to see if the box could download that file at all. As long as that is not possible, it's pointless to look at MetaRepository.
    That is an option. There is already a local repository defined in MetaRepository, you only have to create a subdirectory MyRepo in the admin share. But you can also add another one. That subdirectory is treated exactly the same as an external one, so it needs a ZYPKG_INFO.tgz or ZYPKG_INFO file which describes the packages in that directory.
