How to add city to SSL certification request?
Is there any way to add city information in Zyxel NR7101 when creating SSL certification request because some Dynamic IP hosts requires that information when trying to create SSL certificate?
Hi Friday!
Yes, I see there is no field for the city but e.g. No-Ip demands city information when try to do SLL certification.
Hello @HQWR
Welcome to the forum.
I guess that it depends on what information the Certificate Authority requires before they will generate a certificate.
https://www.digicert.com/kb/csr-creation.htm is what DigiCert say, where they say that the location can be finalised after the Certificate Signing Request has been generated.
https://knowledge.digicert.com/solution/SO16317.html says that for DigiCert's International customers they require either a City/Locality or a State/Province field.
You might want to try getting a certificate from DigiCert as they are a big provider of certificates…
If I click the link to the certificate provider's knowledge base on the following no-ip webpage https://www.noip.com/support/knowledgebase/configure-rapidssl-basic-dv-ssl it goes the the DigiCert CSR creation page linked above. :-)
Kind regards,
Tony
- 588 USG FLEX H Series
- 477 News and Release
