LTE firmware for SBG3600
Hi @Nico2786
Do you mean that after uploading the module firmware, your LTE doesn't work anymore? What's your SBG3600 firmware and can you connect to the console, do some LTE operations and send me via private message regarding to what had been shown in the console?
Hy Zyxel! I'm nico2786login as: admin
admin@192.168.22.1's password:
> lte get
Usage: lte config [--username <username>]
[--password <password>]
[--pin <pincode>]
[--puk <pukcode>]
[--apn <apn>]
connect
disconnect
reconnect
state [up|down]
show [cfg|stats|rilcmd|bytes]
====== Only for production line used =====
get simstatus
get imei
get band
get fwver
get signal
set imei [imei_code]
set band [3|7|8|20|all] 3:1800MHz, 7:2600MHz, 8:900MHz, 20:800MHz
fwupgrade
rilcmd [start|stop]
> lte fwupgrade
> lte get imei
ATCMD [AT+CGSN]
Opening TTY device failed, retry...: No such device
^C > lte get fwver
ATCMD [AT+CGMR]
^C >any command about lte reply:Opening TTY device failed, retry...: No such device
Hi @Nico_Ecomec
Sorry to hear about this. It seems that somehow your LTE module can't be detected by the SBG3600 anymore. I'm not sure what happened when you upgrading the LTE firmware.You may need to contact Zyxel local representative and go through the RMA process.
Hi!If i check from web interface the module read imei of modem and the imei of sim.... lte module are detected because read imei.....I think the first is a solution to upgrade fimrware lte of device and the next step ugprade firmware of router...I need new firmware please...
Hi @Nico_Ecomec
So you're still running on the previous module firmware version. I will send you a private message to download the module firmware.
Hi @Zyxel_Vici upgrade the firmware lte.. but after reboot the version ALT3100_04_05_06_10_B8_LO remaing the same....so start with
ALT3100_04_05_06_10_B8_LO versionupgrade with firmware_ALT3100_05_00_02_00_81_MS.binafter reboot the version is
ALT3100_04_05_06_10_B8_LONot is possible upgrade firmware....
Hi @Nico_Ecomec
You may need to go through the RMA process if changing the module firmware still can't bring your LTE module back.0 -
Hi, i have same problem with LTE firmware after upgrade firmware software. Can you please send the new LTE firmware file?Thnak you!Zyxel SBG3600Current Firmware Version: ALT3100_04_05_06_10_B8_LO
Current WWAN Package Version: 1.15
Current Firmware Version: V1.00(AAKO.9)0
- 439 Beta Program
- 2.8K Nebula
- 202 Nebula Ideas
- 6.3K Security
- 515 USG FLEX H Series
- 328 Security Ideas
- 49 Wireless Ideas
- 289 Service & License
- 461 News and Release
- 4.3K FAQ
- 97 Security Highlight
