Nebula device offline possible reasons
Zyxel_CSO
There are possibilities lead Nebula devices offline on Nebula Control Center.
[First]
You may not plug a power cord into your Nebula device(s).
[Second]
Your device(s) may have a hardware issue or it's faulty.
[Third]
Your device(s) might have the following network issues:
Test port 4335
Test port 6667
[First]
[Second]
[Third]
- The device(s) does not get an usable IP address.
- The device(s) cannot reach TCP port 4335/6667.
- The device(s) cannot synchronize Network Time Protocol(NTP) via UDP port 123.
- The device(s) DNS cannot resolve d.nebula.zyxel.com.
Test port 4335
Test port 6667
Zyxel Nebula Support
Ich kann mich mit meinem NWA50 AX nicht mehr im WLAN verbinden, es blinkt grün rot der Wlan Name ist auch der Standard Name wie kann ich das Gerät wieder verbinden ?
Bitte um Hilfe
my unit has a fast flashing blue light - there doesn’t seem to be a definition of this status but I cannot connect the unit - what am I doing wrong?
Hi
Please reference the LED status table. If it isn't listed, please record a video for us to check.
Also, you can try using ZON to find your AP and access it.
How to use ZON utility? — Zyxel Community
In addition, if your AP is running Nebula mode, please find the password in your Nebula site setting.
What is the password for APs managed by the Nebula cloud? — Zyxel Community
Zyxel Melen0
- 220 Nebula Ideas
- 606 USG FLEX H Series
- 346 Security Ideas
- 482 News and Release
