ZyXEL 5101 NR
2»
  • da_V
    da_V Posts: 1 image  Freshman Member
    Is there a way to disable the LEDs?
    Best Regards
  • UK5Geeee
    UK5Geeee Posts: 2 image  Freshman Member
    I wrote a longer reply but seem to have deleted it before posting! Flashing blue just means you have an unread SMS. You can use the Zyxel Air APP or login to the gateway and read/delete the SMS, then the light stops flashing.
    Blue = receiving 5G from your local RAN site.
    Green = 4G
    Hope that helps.
  • jamessteve
    jamessteve Posts: 1 image  Freshman Member
    @pizza tower: I think the blinking of the blue LED may indicates connection or synchronization issue: The blue LED may blink if there is a problem with the modem's connection or synchronization with the internet service provider (ISP). This could be due to issues with the physical connection, such as a loose cable or a problem with the ISP's network.
