I cannot forward port 80? ARMOR G5 router question!
The behavior does not change on the latest firmware V1.00(ABSK.8)C0 , I think, port 80 is not available on armor G5.
As @Zyxel_Can said,
Armor G5 can’t make port forwarding from the system-reserved ports.However, you can make port forwarding from another port to internal port 80.
Sell this garbage and buy something real. I did it the same way. It will not work zyxel is too incompetent to make this happen. I can recommend you to have a look at the Qnap QHora-301W. I use this one and am very satisfied.
Zyxel wants the customer to buy a very expensive firewall for this feature, which is absolutely outrageous.0
- 440 Beta Program
- 292 Service & License
- 4.6K FAQ
