NSA221 - Size of HDD Rails
I have recently obtained a second-hand NSA221 but the HDD rails are missing.
I can't find these listed anywhere on the Internet so will have to improvise.
Wondered if anyone can confirm the width and thickness of these rails please?
  • suisei
    suisei Posts: 118  Ally Member
    First Comment First Answer Friend Collector Second Anniversary
    I think the model is too old, maybe you could consider with new NAS model.
  • AndyHuk
    AndyHuk Posts: 5
    Thanks for the reply.
    I always think replacing something that works perfectly just because it "old' is a terrible waste of money and certainly not very environmentally conscious!
    In the end I bought three sets of rails for less than £2 and modified them until the fit was correct.
    The result, new discs fitted and NAS working fine - apart from the annoying features (like auto power on/off not working properly) that Zyxel appear to have never bothered to fix 🙁..... another good reason Not to buy another Zyxel NAS replacement!!
  • Mijzelf
    Mijzelf Posts: 2,931  Guru Member
    :thumb:
    Can you elaborate on that? What is it supposed to do, and what does it do?
  • AndyHuk
    AndyHuk Posts: 5
    I have to retract my previous comment and apologise!
    In seeing this post I tried the config again to provide some notes on the problem and found it was simply operator stupidity 😒 Although I'd clicked "Apply" in the Power Control Schedule List, I had failed to click Apply again in the main Power Management screen so the schedule wasn't actually being enabled. Having followed the process correctly it does work 🙂
    The last remaining grumble is the fact that it's no longer possible to download any packages which means one has to set-up a back-up schedule in a fairing complex way that is dependent on an external PC being powered up.
  • Mijzelf
    being powered up.
    I have a backup of the firmware 4 packages here, and normally you can use MetaRepository to access them. There are 2 caveats, MetaRepository only runs on EABI firmware. When I remember well that is firmware 4.4+ for the 221. And the 2nd caveat, I don't know if the backup packages are compatible. They work on the 320, 310 and 325, but I'm not sure about the 210 and 221. I think they will run, but I have no feedback about that. And I don't own a 2xx myself. (Except for an 220, but that is even older, and never had an EABI update)
  • AndyHuk
    AndyHuk Posts: 5
    Thanks very much for your reply again.
    Although I'd searched for alternative repos of the packages I had not come across this so it is REALLY useful.
    But one follow-up question if I may please….
    I've followed the instructions and successfully retrieved/installed MetaRepository, which appears to make a list of packages available. But, this seems to be the list of packages from the fw4 directory. The back-up planned package I need is in the fw4_stock_packages directory - but I can work out how to retrieve those. Can you advise me please?
  • Mijzelf
    Have a look at the webinterface of the MetaRepository package. Here you can add extra repo's. (And remove the defunct ZyXEL repo)
  • AndyHuk
    AndyHuk Posts: 5
    That's great thanks. Worked it out and got the backup package installed successfull.
    Now have some trouble-shooting to do when I get time..... I've successfully created a few back-up jobs. Within the Backup screen of the web GUI I see the last and next execution time but the job had very short execution time and does not generate a backup. Looking in the log section of the web GUI I see the jobs always fail, although the error message doesn't give much clue as to the actual cause:
    [schedule] Job [Test] is resulted as failed
