NR7101 low speed - unable to fix
TLDR: Despite latest firmware and proper debugging and I'm not getting speed higher than 90MB/s on my NR7101 when my iPhone is getting speed higher than 500MB/s at the exact same spot.
On the NR7101:
- has V1.00(ABUV.8)C0 and RG502QEAAAR13A02M4G (various versions didn't change behavior)
- Tried to do a factory-reset config in case stream of firmware updates had messed things up
- Only change to default config is moving to routing mode (vs. IP passthrough)
- APN configuration well taken from SIM card, similar to phone, etc.
- Checked with Swisscom that SIM card has no limitation - it is part of the same subscription as the iphone
- Current 5G status attached
- behavior has been there for >1 year - so not a one-time issue
iPhone:
- 13 Pro, latest firmwares
- Printscreens attached, including 5G status
Any idea how I can solve this? I went through all ZyXEL support campus articles I could find but none of them solved it
Thanks,
sacha
The nr7101's speedtest is useless use ookla's there too. Try disable B1, B28 bands in the settings and try again. Network setting - Broadband - Cellular Band
My enabled bands:
SINR only 6, maybe a bit low
Pointing it exactly to the cell?
Check also this!
monstrmprz, thanks for the feedback
I did as you suggested and tried to play with which B* band was left but nothing improved - same type of bandwidth range. BTW, I saw two empty answers from you before this one, was that by design or is this a bug of the website?
Good idea SELBERG, I checked and we are at Full gigabit.
6 is a bit low, went up to 12'ish but had no impact. I could stay at 12 (would need to move antenna) but isn't the priority as it can't seem to get higher so problem is somewhere else it seems.
Bug. When i write on phone, this happens. Very annoying when you write a long comment and when you post the comment the text is disappeared…only works from phone when desktop mode is enabled
If you start writing on line 2, the text remains. Now I'm writing from my android....
Really! Does it work with messages too?
- 3K Nebula
- 223 Nebula Ideas
- 6.6K Security
- 628 USG FLEX H Series
- 353 Security Ideas
- 85 Switch Ideas
- 54 Wireless Ideas
- 299 Service & License
- 492 News and Release
- 108 Security Highlight
