Zyxel nebula dashboard says switches are offline
13»
  • Zyxel_Melen
    Zyxel_Melen Posts: 3,722  Zyxel Employee
    Hi @Ricardo_ITS,
    Thanks for the tech support. I have deleted it from the public to protect privacy. I will back to you soon.
    Zyxel Melen
  • Ricardo_ITS
    Ricardo_ITS Posts: 12  Freshman Member
    Any info abut this please?.
  • Zyxel_Melen
    Hi @Ricardo_ITS,
    After checking the tech support, I found the switch disconnected due to the connection expired. Could you help to take a test for clarification?
    1. Please connect a PC to the switch in the problem subnet.
    2. Open any browser and visit "http://portquiz.net:4335" and "http://portquiz.net:6667".
    Zyxel Melen
  • Ricardo_ITS
    In the case of port 6667, the result is the same in my network, in the client network or even in my home network, it is something that I already tried last week since I read it in a post here in this community
  • Zyxel_Melen
    edited August 2023
    Hi @Ricardo_ITS,
    Thanks for your feedback.
    Could you help to enable Zyxel support access for me to confirm the configuration between Nebula and tech support?
    Also, since you mention " it does not receive any communication from those ports.", may I know how you clarify it?
    At last, could you please help to check the below:
    1. Is there any IP conflict?
    2. Is the MTU size on the firewall 1500?
    3. Is the cloud LED steady green or steady amber?
    Zyxel Melen
Nebula Tips & Tricks
