ZyXEL 5101 NR
Is there a way to disable the LEDs?
Best Regards
I wrote a longer reply but seem to have deleted it before posting! Flashing blue just means you have an unread SMS. You can use the Zyxel Air APP or login to the gateway and read/delete the SMS, then the light stops flashing.
Blue = receiving 5G from your local RAN site.
Green = 4G
Hope that helps.
@pizza tower: I think the blinking of the blue LED may indicates connection or synchronization issue: The blue LED may blink if there is a problem with the modem's connection or synchronization with the internet service provider (ISP). This could be due to issues with the physical connection, such as a loose cable or a problem with the ISP's network.
- 220 Nebula Ideas
- 606 USG FLEX H Series
- 482 News and Release
