NR 7101 Kernel 2 deleted
Bergbahnfreak
Bergbahnfreak Posts: 3 image  Freshman Member
edited January 2024 in Mobile Broadband
Hello dear community!
I deleted kernel 2 on my NR 7101 and now the device no longer works! The LED light only flashes red. And the PC only has a short connection and cannot identify the network during this time.
Do you perhaps know how I can get the firmware running again or is the device now scrap?
Best regards
Bergbahnfreak
Edit: sorry for posting in the wrong category
  • Internetheavyuser
    Internetheavyuser Posts: 96 image  Ally Member
    Could you descrice how you did that?
    Can you login WebGUI?
  • Bergbahnfreak
    Well, I installed OpenWRT on the device, but I wasn't satisfied with it and wanted to go back to the original firmware and somehow an error happened to me.
    Unfortunately I can no longer access the WebGUI because the device can no longer be identified.
  • Internetheavyuser
    If you installed the non-official FW or SW to make the device crash. I think it is not able to recover from it. Have you tryed reset to default?
    Otherwise you need to ask for RMA and pay for the maintenance fee
  • Bergbahnfreak
    Sorry for the late reply, I was on vacation.
    I've tried restoring the default settings using the reset button to no avail.
    RMA is not possible as I bought the device used and the first owner appears to have purchased this device from an ISP.
    Kind Regards,
    Bergbahnfreak
