LTE7490-M904 cant disable ip passthrough mode
Hello,my firmware is V1.00(ABQY.6)C0 , ip passthrough it's giving my internal network some problems expecially at the solaredge inverterS (a pair in primary-secondary configuration active-active) that cannot contact their network monitor ips . So my idea was to disable my IP passthrough and have a nat on my lan.. problem is, following user manual section 6.8 - Networksettings - broadband i dont have any option to disable/enable ip passthrough.. seems like the submenu / option it's missing. From Home - Cellular Info box i can confirm Ip Passthrought it's enabled.. any help?
below you can see my menus without the ip passthrough toggle avaible…
Let me know.
Best Regards
Danilo.
Best Answers
You can check Broadband → Cellular APN click Modify on APN1 and you can see there is a IP Passthrough → disable it and press OK in the bottom of the page.
It works like a charm... The options was exactly there...
You basically beat the official support that its still linking the wrong documents... I suppose with the firmware updates and modify at the gui interface they have to think about updating their KB and User guide
- 588 USG FLEX H Series
- 477 News and Release
