NR7101 - Menu-entry for Interface Group is missing
I want to enable IP Passthrough between WAN and LAN (not using WLAN). I get an error message say interfaces have to be in same Interface Group. In manuel a menu item 'Interface Group' exist, but in my web interface such item under Networking does not exist. I'm a bit lost then
Peter
It's here:
Thanks. Issues is that last item under Network Setting is 'VLAN Group'.
I'm using Chrome, so I do not expect it to be a browser issue.
?0 -
Attached is a picture on how it looks at my web interface. Is 'internet Group' menu item dependent on other settings?
Regards
Peter
What is your FW version?
And can you show me how you set the IP passthrough and show me the error message?
FW-version
Step 1 - Enable Passthrough
Step 2 - Warning / Error message
Step 3 - When clicking on 'ok' ⇒ return til Step 1
Thanks for looking into my case.
Br Peter
Did you reset to default when upgrade the FW? If not, please do it.
Maintenance → backup/ restore → reset to default
When you connect to NR7101 through GUI did you use ethernet cable connect to POE or WiFi?
No, I did not reset to default. I'll do later and report back.
I'm accessing GUI through ethernet with PoE as NR7101 is position a bit far away./Peter
Hi, just a short update. Problem solved. Thanks.
I did reset through GUI, but it didn't work well. A hardware reset did the trick.
After reseting NR7101 was in bridgemode (IP Passthrough) concering WAN+LAN interface by defalut. WLAN on default Internet Group.
I guess comming from a situation with an active settings to no IP Passtrough uploading firmeware with default expected setting to be IP Passtrhough gave cause to the problem.2
- 435 Beta Program
- 176 Nebula Ideas
- 428 USG FLEX H Series
- 298 Security Ideas
- 274 Service & License
- 422 News and Release
- 89 Security Highlight
