NWA50AX keep rebooting every 2-3 minutes and I can’t reached web config.
Mo7d
Mo7d Posts: 2 image  Freshman Member
edited May 2024 in Wireless
Hi
I have ap nwa50ax and it kipping restarting every 2-3 minutes. and I can’t access to web config. When I enter the IP address the web config work some second and the IP address page (the page is not reached) and the ap nwa50ax work fine but can’t open web confg.
NCC unlicensed
Thanks Advance
Have a nice day 💐
Sorry to my bad language
  • Zyxel_Kay
    Hi @Mo7d ,
    Here are some steps you can take to troubleshoot the problem:
    1. Reset Your AP to Factory Default.
      1. If your AP is currently registered under Nebula cloud mode, please remove it from the organization and switch it to standalone mode. You can find step-by-step instructions in this article:
      2. Then, press and hold the reset button on the AP until the LED blinks(This typically takes around 10 seconds).
      3. Attempt to access the AP's local web GUI after the reset to see if the AP stabilizes. Please let us know if you encounter any improvements.
    2. Upgrade to The Latest Firmware.
      To ensure your AP's optimal performance, consider upgrading it to the latest firmware(V6.29P1) through ZON utility. You may refer this article for upgrading firmware by ZON:
    If the problem persists, kindly provide us with the following details to help us further diagnose the issue:
    1. Provide us your AP’s S/N and MAC address through private message.
    2. Please let us know when the AP started repeatedly rebooting. Did this condition begin immediately after the first installation or after a specific action?
    3. What is the current firmware version installed on your AP?
    4. How is your NWA50AX powered? Is it using PoE (Power over Ethernet) or a power adapter? Please ensure that the AP is receiving sufficient power to operate.
    Alternatively, if your AP is under Nebula Cloud mode, enabling Zyxel Support and providing your org/site name will help us directly investigate your site.
    Kay
  • Mo7d
    Hi @Zyxel_Kay
    thanks for your replay
    i remove it from the organization as your step but the same problem I can’t access to web config its load same second and the IP address page (the page is not reached)
    please help me
    i will send s/n and mac address private message
    than get this page
  • Zyxel_Kay
    Hi @Mo7d
    As we've discussed in private msg, the symptom exhibited by your AP indicates a hardware issue. Kindly reach out to your local reseller to initiate the RMA process.
    Kay
