Using an SCR 50AXE as standalone AP (only)?
neukrisz
neukrisz Posts: 5 image  Freshman Member
edited August 2023 in Nebula
Dear Community,
Is there any trick in order to use my "unnecessary" SCR 50AXE unit as an AP (only) in my system?
Currently I have a GS1920-24HPV2 switch and 4 Zyxel APs already. I'd like to extend the WiFi further…
Thanks in advance!
  • Zyxel_Jerry
    Zyxel_Jerry Posts: 1,406 image  Zyxel Employee
    Hi @neukrisz
    The SCR 50AXE model will not include the MESH feature. For extending WiFi service, an Ethernet connection will still be required.
    However, we have a plan to add mesh system in future products.
    If you have any further inquiries or suggestions, please feel free to let us know.
  • neukrisz
    Thanks for your reply!
    Without MESH can we use that as standalone AP only? (so has it AP mode only?)
    Thanks in advance!
  • Zyxel_Jerry
    Hi @neukrisz
    Thanks for the feedback.
    There is no AP only feature on SCR 50AXE.
  • neukrisz
    Thanks!
    Is there any plan for implement this feature in the future?
  • Pook
    Pook Posts: 153 image  Master Member
    First Comment First Answer Friend Collector Nebula Gratitude
    You could use as an AP, make sure DHCP is off and give the LAN interface a suitable free static IP, and Bingo you have an AP. Devices that join the Wi-Fi will get an IP address from your LANS DHCP server.
  • PVDPeer
    PVDPeer Posts: 1 image  Freshman Member
    I bought this router in the assumption that an enterprise grade AP wouldn't miss such a function but it does. Now I hope your suggestion can help me. But so far I haven't been able to get this to work. I disabled the DHCP server on the Zyxel. I configured an IP address in the same window where you configure the DHCP server that is within the subnet configured on my OpnSense server.
    But it doesn't even matter if I connect the Zyxel to any of the 4 LAN interfaces or the WAN interface, no result. I can connect with my devices but no internet, no LAN access.
    Also, if I connect the WAN interface to the network, the nebula led lights up yellow. If I connect it through one of the LAN interfaces, the nebula led doesn't even light up. All my devices have internet over the same switch.
    Wether I connect over the old or new access point, I can't connect to the IP address of the Zyxel either.
    Have you got any idea?
Nebula Tips & Tricks
