Using an SCR 50AXE as standalone AP (only)?
neukrisz
neukrisz Posts: 5
edited August 2023 in Nebula
Dear Community,
Is there any trick in order to use my "unnecessary" SCR 50AXE unit as an AP (only) in my system?
Currently I have a GS1920-24HPV2 switch and 4 Zyxel APs already. I'd like to extend the WiFi further…
Thanks in advance!
  • Zyxel_Jerry
    Zyxel_Jerry Posts: 1,376 image  Guru Member
    Hi @neukrisz
    The SCR 50AXE model will not include the MESH feature. For extending WiFi service, an Ethernet connection will still be required.
    However, we have a plan to add mesh system in future products.
    If you have any further inquiries or suggestions, please feel free to let us know.
    Zyxel
    Untitled Image
  • Thanks for your reply!
    Without MESH can we use that as standalone AP only? (so has it AP mode only?)
    Thanks in advance!
  • Zyxel_Jerry
    Hi @neukrisz
    Thanks for the feedback.
    There is no AP only feature on SCR 50AXE.
    Zyxel
    Untitled Image
  • Thanks!
    Is there any plan for implement this feature in the future?
  • Pook
    Pook Posts: 151 image  Master Member
    First Comment First Answer Friend Collector Nebula Gratitude
    You could use as an AP, make sure DHCP is off and give the LAN interface a suitable free static IP, and Bingo you have an AP. Devices that join the Wi-Fi will get an IP address from your LANS DHCP server.
  • PVDPeer
    PVDPeer Posts: 1 image  Freshman Member
    I bought this router in the assumption that an enterprise grade AP wouldn't miss such a function but it does. Now I hope your suggestion can help me. But so far I haven't been able to get this to work. I disabled the DHCP server on the Zyxel. I configured an IP address in the same window where you configure the DHCP server that is within the subnet configured on my OpnSense server.
    But it doesn't even matter if I connect the Zyxel to any of the 4 LAN interfaces or the WAN interface, no result. I can connect with my devices but no internet, no LAN access.
    Also, if I connect the WAN interface to the network, the nebula led lights up yellow. If I connect it through one of the LAN interfaces, the nebula led doesn't even light up. All my devices have internet over the same switch.
    Wether I connect over the old or new access point, I can't connect to the IP address of the Zyxel either.
    Have you got any idea?
Nebula Tips & Tricks
