NR 7101 Kernel 2 deleted
Hello dear community!
I deleted kernel 2 on my NR 7101 and now the device no longer works! The LED light only flashes red. And the PC only has a short connection and cannot identify the network during this time.
Do you perhaps know how I can get the firmware running again or is the device now scrap?
Best regards
Bergbahnfreak
Edit: sorry for posting in the wrong category
Could you descrice how you did that?
Can you login WebGUI?
Well, I installed OpenWRT on the device, but I wasn't satisfied with it and wanted to go back to the original firmware and somehow an error happened to me.
Unfortunately I can no longer access the WebGUI because the device can no longer be identified.
If you installed the non-official FW or SW to make the device crash. I think it is not able to recover from it. Have you tryed reset to default?
Otherwise you need to ask for RMA and pay for the maintenance fee
Sorry for the late reply, I was on vacation.
I've tried restoring the default settings using the reset button to no avail.
RMA is not possible as I bought the device used and the first owner appears to have purchased this device from an ISP.
Kind Regards,
Bergbahnfreak
- 431 Beta Program
- 2.6K Nebula
- 165 Nebula Ideas
- 6K Security
- 364 USG FLEX H Series
- 292 Security Ideas
- 1.5K Switch
- 42 Wireless Ideas
- 6.6K Consumer Product
- 262 Service & License
- 407 News and Release
- 87 Security Advisories
- 3.9K FAQ
- 83 Security Highlight
