NWA1123-AC-PRO connect lan to switch
I have a NWA1123-AC-PRO device. I would like to connect a zyxel unmanaged switch to the LAN1 port to branch the cable network. When I connect the switch to lan1 AP. Internet not working. However, if I connect the laptop directly to lan1, everything works. Why is this happening?
Hi @kalgontbg
First, please try rebooting your switch and then reconnect it to the LAN1 port of your AP. Sometimes, a simple reboot can help resolve connection problems.
If the issue persists despite the reboot, we kindly request additional information to better assist you
- Model of your Zyxel unmanaged switch.
- Current firmware version of NWA1123-AC-PRO.
- Have you tested whether the switch works properly when connected to other devices (such as a router)?
- Could you provide information about the LAN1 LED status of the NWA1123-AC PRO while it was connected to the switch and the laptop?
- Beyond the laptop connected to LAN1, are the WiFi clients connected with the NWA1123-AC-PRO’s SSID able to access the internet?
- Please enable Zyxel Support in Nebula > Help center, and provide us with your org/site name. This will aid us in diagnosing the issue more effectively.
Kay
- 588 USG FLEX H Series
- 476 News and Release
