External device controlled through Zyxel LTE7480-M804
VeeJii
Hei! I need to control remotely a measurement device connected to Zyxel LTE7480-M804 LTE modem. I already have a fixed IP address connection for the modem from my ISP but have been unable to create a connection through the modem to the device. Even the professionals at ISP support couldn't get it working.
So how should I adjust the modem settings to make it work? Attached pdf shows the setup at the remote site. The measurement device is some 10-15 years old and so maybe does not have some newer TCP/IP features. Thank you for you help!
I think you can check the connection step by step.
- Is LTE7480-M804 able to connect to the internet ?
- If LTE7480-M804 in routing mode?
- Is your laptop able to connect to the internet through LTE7480?
- Can you measurement device ping 192.168.1.1?
- Is you measurement device able to use trace route to 192.168.1.1?
Knowing the above answer, we can continue the examination.
- 588 USG FLEX H Series
- 476 News and Release
