Zyxel NWD7605 on Linuxmint 21.1
I've just acquired a Zyxel NWD7605 USB dongle to use it on a PC with Linuxmint 21.1 OS. I've downloaded the Linux drivers from you site, but I'm not being able to compile it with the script provided.
Any special configuration I have to apply on the Makefile or any other component?
Regards,
Hi @pfonseca
Please try with below command.
tar -xzf NWD7605 Linux_Driver_1.0.0.22.0301.tar.gzcd RTL8852BU_RTL8832BU_WiFi_linux_v1.15.11-36-g66c244572.20220902
chmod +x install
./install.sh
If it cannot install, please PM us the error message0 -
Hi Jerry,
I attach the file that shows the error when I try to make (compile) the driver.
Anyway, I was able to put the adapter working with this instructions , but only when I upgrade to 5.19.xx Linux Kernel. Without that I had obtained an error similar with the one I have with your driver when I try to make it.
So, I think the issue is that your sources have to be adjusted to newer version of kernel, or even better, be included on kernel modules of several Linux distros.
The driver I've compiled allows me to connect to several different WiFi technologies, even WiFi 6. The only thing that is not working are the leds on adapter.
Please advise and thanks for your quick answer.
Regards,
Hi @pfonseca
Thanks for the valuable feedback.
We will work towards implementing improvements to address this issue and ensure a smoother installation experience across various Linux kernel modules.1 -
Hi Jerry,
For now, the adapter is working with the solution I mentioned.
Keep me posted, please, on the evolution of the drivers.
Regards,
I am using new linux distros with kernel 6.4 6.5
and I can't compile this driver.
It gives me the error as you can see ;
/usr/src/RTL8852BU_RTL8832BU_WiFi_linux/os_dep/osdep_service_linux.c: In function ‘rtw_change_ifname’:
/usr/src/RTL8852BU_RTL8832BU_WiFi_linux/os_dep/osdep_service_linux.c:810:28: warning: passing argument 1 of ‘_rtw_memcpy’ discards ‘const’ qualifier from pointer target type [-Wdiscarded-qualifiers]
810 | _rtw_memcpy(pnetdev->dev_addr, adapter_mac_addr(padapter), ETH_ALEN);
/usr/src/RTL8852BU_RTL8832BU_WiFi_linux/os_dep/osdep_service_linux.c:48:24: note: expected ‘void *’ but argument is of type ‘const unsigned char *’
48 | void _rtw_memcpy(void *dst, const void *src, u32 sz)
/usr/src/RTL8852BU_RTL8832BU_WiFi_linux/os_dep/osdep_service_linux.c: In function ‘rtw_random32’:
/usr/src/RTL8852BU_RTL8832BU_WiFi_linux/os_dep/osdep_service_linux.c:850:16: error: implicit declaration of function ‘prandom_u32’; did you mean ‘prandom_u32_max’? [-Werror=implicit-function-declaration]
850 | return prandom_u32();
| prandom_u32_max
cc1: some warnings being treated as errors
make[2]: *** [/usr/src/linux-headers-6.1.0-11-common/scripts/Makefile.build:255: /usr/src/RTL8852BU_RTL8832BU_WiFi_linux/os_dep/osdep_service_linux.o] Błąd 1
make[1]: *** [/usr/src/linux-headers-6.1.0-11-common/Makefile:2037: /usr/src/RTL8852BU_RTL8832BU_WiFi_linux] Błąd 2
make[1]: Opuszczenie katalogu '/usr/src/linux-headers-6.1.0-11-amd64'
make: *** [Makefile:633: modules] Błąd 2
I tested different live distributions and it's the same everywhere0 -
The release notes mention support for kernel up to version 5.19. It appears that it does not extend to versions 6.4 and 6.5
Hi wlodarek,
I'm using this driver and I think will fit your needs. If not, place a issue, morrownr will be able to fix any issue, I guess.
- 3K Nebula
- 223 Nebula Ideas
- 6.6K Security
- 628 USG FLEX H Series
- 354 Security Ideas
- 85 Switch Ideas
- 54 Wireless Ideas
- 299 Service & License
- 492 News and Release
- 109 Security Highlight
