Sonos connection
Have installed 2x nwa50ax in our home. Since the installation I cannot access the Sonos appliances via the Sonos app. The speakers are connected and listed in the clients list in Nebula but the Sonos app does not see them. Fyi, all other devices(PC, tablet, etc) seem to function correctly on the Zyxel Aps
If however the speakers are connected via Ethernet everything works, weirdly airplay device shows up over wifi but does not play. (also works over Ethernet)
Any ideas?
Hello @userAti
The "Tagging" feature on the SSID page doesn't pertain to VLANs. It is designed to assign specific SSIDs to designated APs. For instance, tagging an AP with “Lobby” and assigning the “Lobby” tag to SSID_lobby means only that AP will broadcast SSID_lobby. For a step-by-step guide on this, refer to:
Your current setup has both APs with same tags (1, 25, 50). This means both APs are broadcasting SSIDs 1, 3, and 4 based on their associated tags.
For VLANs, you've assigned VLAN 1 to SSID 1, which serves as the untagged management VLAN. Additionally, VLAN 25 is set for SSID 3, and VLAN 50 for SSID 4. It's crucial to ensure that any uplink devices, like switches and DHCP servers, are appropriately configured to align with VLANs 25 and 50.
Several factors can block wireless device communication:
- Devices connect to different SSIDs on separate VLANs, which are set to not interact on the uplink device.
- Devices connect to the same SSID but different APs, and the uplink device linking the APs has port isolation or layer 2 isolation activated.
Additionally, the Sonos APP and device utilize SSDP for discovery, relying on multicast traffic. Ensure the uplink devices in the network have IGMP snooping set up correctly for efficient multicast traffic forwarding.
Nami
Hello @userAti
From your description, it seems there's an issue with the Sonos app's ability to discover and communicate with your Sonos devices over the wireless network.
Connectivity and Configuration Checks:
- Ensure that the smartphone with the Sonos app and the Sonos devices are connected to the same SSID.
- Ensure that traffic between wireless devices isn't blocked by specific configurations. To verify this, navigate to
Configure > Access points > SSID advanced settings, select the specified SSID, and check if theLayer 2 isolationandIntra-BSS traffic blockingoptions are enabled. If they are active, they might be blocking traffic between wireless devices, and you should consider disabling them.
If these two features are already turned off, and both your phone and IoT devices are on the same SSID but connected to different APs, their communication might be obstructed by the uplink device connecting the two APs. Could you let us know which uplink device you're using to connect the two APs?
Recommendations for IoT Devices:
We suggest setting up a dedicated SSID that operates exclusively on the 2.4GHz band for IoT devices. This can enhance the connectivity and performance of such devices. Here are detailed FAQ:
Nami
Hi Zyxel Nami,
Layer 2 isolation and intra traffic blocking is already off.
I found that I had to set in "WiFi SSID settings" → "Tagging" to match the "VLAN ID", I also had to set the "Site-wide → Devices→Access points → NWA50ax(as mac)→ "Tag" to match the "VLAN ID".
Now it works, will report if anything changes.
The "VLAN ID" in this case is 1, the default Lan, which is untagged I believe?
I do not have a deep understanding of networking, so maybe you could explain this behaviour ?
Regrads,
Ati
Hello @userAti
Nami
- 441 Beta Program
- 209 Nebula Ideas
- 534 USG FLEX H Series
- 338 Security Ideas
- 51 Wireless Ideas
- 295 Service & License
- 461 News and Release
