LTE7490-M904 troubleshooting
Hyuffo
Hyuffo Posts: 1
edited January 2024 in Mobile Broadband
Hi there!
I just wall mounted a LTE7490-M904 in my mountain house using a SIM card by TIM (Italian ISP) and everything works fine on the control panel. I can perform ping and speed test as well with promising results. As soon as I try to configure a Google WiFi AP using the LAN cable, it detects no internet connection. I then tried to connect my MacBook to the internet using the LAN cable with a RJ45 to USB-C adapter but id doesn't work as well. Am I missing some steps? In attachment you can find a screenshot from the main page.
Thanks in advance for your help!
  • Internetheavyuser
    Internetheavyuser Posts: 96 image  Ally Member
    Did the Google WiFi AP get the IP from LTE7490-M904? EX: 192.168.1.X
    "I then tried to connect my MacBook to the internet using the LAN cable with a RJ45 to USB-C adapter but id doesn't work as well. "
    I saw you can log in GUI of LTE7490 means MacBook is able to connect to LTE7490.
    Can you try to ping from MacBook?
    EX: ping 8.8.8.8 and traceroute www.google.com
    Screen shot the result so we can better understand your situation.
    Or you can try to switch router mode to IP passthrough.
    Broadband → Cellular APN click Modify on APN1 and you can see there is a IP Passthrough → disable it and press OK in the bottom of the page.
