NR7101
Hello I'm considering purchasing a NR7101, and I had some initial setup questions, once installed I would like to use the Nr7101 in Bridge Mode and use an Asus router for Wifi is this possible? And if so how is this done?
it is possible, and in fact what this product is supposed to be useful for, but having gone down a similar route, with a Synology router I wouldn't recommend it for several reasons. First performance is poor compared with other 5G modems, second it's physically much more cumbersome to install, third configuration to be able to get to it's configuration pages is very convoluted compared to other 5G modems that are just plug and play
I appreciate your feedback if this is the case then Ill probably not go down this route
- 220 Nebula Ideas
- 608 USG FLEX H Series
- 299 Service & License
- 482 News and Release
