Setup Multy M1 in Access Point mode? How?
I am trying to connect these to my network, but the initial setup page I accessed via the website will not run without plugging the M1 into my network via the LAN port and then I have all kinds of issues. Is there an easy way to add this device as an access point?
I have configured my DHCP server to allocate IP addresses to the M1 units' MAC addresses via address reservation, but the M1 is running it's own DHCP server.
Main issues I am having:
I can't change the device IP.
I can't disable the DHCP server.
I've only connected one of these so far by wired connection, but I want to have all three running with wired backhaul, like this:
I'm still having a lot of trouble with this. Two of the M1's have now set up fine by changing the Operating Mode and I will test the mesh / roaming capability shortly. However, the other M1 will not go past the auto-config script at the beginning (a really bad UI decision). I've reset / restarted multiple times.
I found the system page to change the operating mode (by going to it directly) but it doesn't seem to have any effect / sometimes the page does not even load.
I did find and accessed the upgrade firmware page:
http://192.168.1.245/gui/#/main/debug/firmwareupgrade
However, I can't see anywhere on the Zyxel site to download the firmware? Can anyone provide a link?
Looking at the JSON between the router and my web client I found a firmware upgrade location of:
So I guess I will try running that through the debug firmware update page…
Hi @ojobson
We can help you to upgrade the firwmare.
I have PM you, please check the message box.0 -
I wiped/reset all the devices and then tried again using the mobile app this time. I had to jump through a few hoops - I think I didn't have the network cable plugged into the right ports on the M1s (It's not clear for my use case which ports should be used on each device) but after a bit of fiddling I got them all working with wired backhaul. A shame that the website management console is so poor.
Is there any option to manage the signal / broadcast power so I can optimise fast-roaming hand-off between the access points? I have some overlap in my network at present.
Hi @ojobson
Thanks for your valuable suggestion.
Multy M1 does not support to limit of the signal power on each Multy device.0 -
That’s disappointing to hear.
I have installed a 3rd party firmware and the hardware is now working flawlessly. I now have access to advanced config options to optimise fast transition (802.11r) on the network. It’s a shame your software team did not develop this properly.
hai, which firmware and how ? Maybe i can do the same!
I have now my new laptop from work and is connected and signal is perfect but no internet.
Worst product i have bought ever. Not stable some devices no internet and it happens all the time! And nobody is helping!
i have just reset all the devices and now all the internet on all the devices are gone!0 -
can somebody send me a pm with instructions to install a stable firmware? It is instable and many problems with laptops with wifi6 on board.
Hi @Cihank
We have contacted you, please check your message box.0 -
yess i saw it and mailed back with time, monday at 16:00 Netherland time
I have to connect them more or less like you did, how did you manage to make them all work via cable? What port should they be connected to?
- 415 Beta Program
- 2.5K Nebula
- 152 Nebula Ideas
- 101 Nebula Status and Incidents
- 5.8K Security
- 296 USG FLEX H Series
- 281 Security Ideas
- 1.5K Switch
- 77 Switch Ideas
- 1.1K Wireless
- 42 Wireless Ideas
- 6.5K Consumer Product
- 254 Service & License
- 396 News and Release
- 85 Security Advisories
- 29 Education Center
- 3.6K FAQ
- 76 Security Highlight
