NAS 325v2 problem with packages installation
Good morning,
I have a problem with installing any packages in the NAS325v2 system. I understand that it is related to the lack of support for the product by Zyxel. Should I change the repository address or package paths somewhere? Is it possible to manually install packages? It's mainly about SSH. I'd looking for an oryginal packages
Yes. Assuming you don't add the quotes in your post.
Thank you. If I add :
"# Backup Zyxel Repository
http://zyxel.diskstation.eu/Users/Mijzelf/zypkg-repo/fw4_stock_packages/"
Its enough?
Thank you. I had some trouble but now I can obtain full list of packages. I have a problem with installing phpMyAdmin it. The zpkg of phpMyAdmin weight about 37MB system show that it should be above 80 MB. Unfortunetely it is a problem with installation. Do you have any suggestion or this package is corrupted?
I'm not aware of any corruption. The installed side in in 'plain bytes', while the package itself is compressed. So a factor of 2 is not strange, for a package mainly containing text. (php files, in this case)
How does the problem occur?
Sorry, i don’t know but now it works. It is like on a doctor visit - when you at the visit everything is Ok but when you were at home you felt a pain 😀
I didn't expect you to know how it works, just a description of how you know that there is a problem.
This is only electronic device. Sometimes something goes wrong with no purpouse. Previous after trying install package (e.i. phpMyAdmin) system shows „no installed” or „unknow” status next to package name with red sign. But now without any changes all packages I want has been installed completetly. However thank you because without your help usfulness of this old device is poor.
- 431 Beta Program
- 2.6K Nebula
- 168 Nebula Ideas
- 6K Security
- 366 USG FLEX H Series
- 294 Security Ideas
- 1.5K Switch
- 42 Wireless Ideas
- 265 Service & License
- 409 News and Release
- 87 Security Advisories
- 3.9K FAQ
- 83 Security Highlight
