How to config WAN trunk in NCC webpage
GiuseppeR
GiuseppeR Posts: 545 image  Master Member
Zyxel Certified Network Engineer Level 1 - Switch Zyxel Certified Network Engineer Level 1 - Nebula First Comment Friend Collector
I see that using USGFLEX500 is useful to set which RJ45 port is WAN or LAN.
Looking into its config inside "Site-wide > Configure > Firewall > Routing" I see where I could set the WAN for backup: here I have the problem to set a WAN trunk, I have a WAN1 as main connection, but I want to use as a backup the WAN2 + WAN3.
Where I can config this on Nebula?
Thanks in advance
Nebula Tips & Tricks
