Power Suppy for NR5103 & NR5103E
bulldog715
bulldog715 Posts: 29 image  Freshman Member
edited January 2024 in Mobile Broadband
Can Zyxel confirming which power supply correct for this hub. 12v 3amp output or 12v 4amp output?
Because someone saying using 12v 3amp or 12v 2amp will caused 5G disconnection! 12v 4amp has solved the problem to stable 5G connected?
  • monkeynia
    monkeynia Posts: 33 image  Freshman Member
    First Answer First Comment Friend Collector Fifth Anniversary
    Hi @bulldog715,
    I found the datasheet of NR5103 shows its power consumption is 48W (peak). So I think it is wise to use a 12v 4amp adapter to avoid any power peak occurring.
    If the device could not get sufficient power, any problem will occur.
  • tonygibbs16
    tonygibbs16 Posts: 979 image  Guru Member
    50 Answers 500 Comments Friend Collector Fifth Anniversary
    edited October 2023
    See also https://confusedbird.com/printthread.php?tid=208
    It talks there about using a 12v 4A Gigabit Power over Ethernet (PoE) device to power the NR5103E.
    Kind regards,
    Tony
  • tonygibbs16
    edited October 2023
    sorry for the empty post earlier.
