Setup Multy M1 in Access Point mode? How?
I am trying to connect these to my network, but the initial setup page I accessed via the website will not run without plugging the M1 into my network via the LAN port and then I have all kinds of issues. Is there an easy way to add this device as an access point?
I have configured my DHCP server to allocate IP addresses to the M1 units' MAC addresses via address reservation, but the M1 is running it's own DHCP server.
Main issues I am having:
I can't change the device IP.
I can't disable the DHCP server.
I've only connected one of these so far by wired connection, but I want to have all three running with wired backhaul, like this:
I'm still having a lot of trouble with this. Two of the M1's have now set up fine by changing the Operating Mode and I will test the mesh / roaming capability shortly. However, the other M1 will not go past the auto-config script at the beginning (a really bad UI decision). I've reset / restarted multiple times.
I found the system page to change the operating mode (by going to it directly) but it doesn't seem to have any effect / sometimes the page does not even load.
I did find and accessed the upgrade firmware page:
http://192.168.1.245/gui/#/main/debug/firmwareupgrade
However, I can't see anywhere on the Zyxel site to download the firmware? Can anyone provide a link?
Looking at the JSON between the router and my web client I found a firmware upgrade location of:
So I guess I will try running that through the debug firmware update page…
Hi @ojobson
We can help you to upgrade the firwmare.
I have PM you, please check the message box.Share your feedback through our survey, make your voice heard, and win a WiFi 7 AP!
I wiped/reset all the devices and then tried again using the mobile app this time. I had to jump through a few hoops - I think I didn't have the network cable plugged into the right ports on the M1s (It's not clear for my use case which ports should be used on each device) but after a bit of fiddling I got them all working with wired backhaul. A shame that the website management console is so poor.
Is there any option to manage the signal / broadcast power so I can optimise fast-roaming hand-off between the access points? I have some overlap in my network at present.
Hi @ojobson
Thanks for your valuable suggestion.
Multy M1 does not support to limit of the signal power on each Multy device.Share your feedback through our survey, make your voice heard, and win a WiFi 7 AP!
That’s disappointing to hear.
I have installed a 3rd party firmware and the hardware is now working flawlessly. I now have access to advanced config options to optimise fast transition (802.11r) on the network. It’s a shame your software team did not develop this properly.
hai, which firmware and how ? Maybe i can do the same!
I have now my new laptop from work and is connected and signal is perfect but no internet.
Worst product i have bought ever. Not stable some devices no internet and it happens all the time! And nobody is helping!
i have just reset all the devices and now all the internet on all the devices are gone!0 -
can somebody send me a pm with instructions to install a stable firmware? It is instable and many problems with laptops with wifi6 on board.
Hi @Cihank
We have contacted you, please check your message box.Share your feedback through our survey, make your voice heard, and win a WiFi 7 AP!
yess i saw it and mailed back with time, monday at 16:00 Netherland time
I have to connect them more or less like you did, how did you manage to make them all work via cable? What port should they be connected to?
- 415 Beta Program
- 2.4K Nebula
- 144 Nebula Ideas
- 94 Nebula Status and Incidents
- 5.6K Security
- 238 USG FLEX H Series
- 267 Security Ideas
- 1.4K Switch
- 71 Switch Ideas
- 1.1K Wireless
- 40 Wireless Ideas
- 6.3K Consumer Product
- 247 Service & License
- 384 News and Release
- 83 Security Advisories
- 29 Education Center
- 3.2K FAQ
- 71 Security Highlight
