Setup Multy M1 in Access Point mode? How?
Hi @Andrea94
Are you interested in configuring the Multy M1 as a Bridge mode?If so, please follow these steps:
1.Start by setting up the main Multy M1 device in Bridge mode.
2.Then, use WPS to pair the satellite node with wireless backhaul.
3.Once both satellite devices are paired, place them where desired.
Since it is in Bridge mode, you can use either the WAN or LAN port on the Multy M1
I didn't explain myself well sorry, I need to make them work in wired backhaul, (not connected in cascade to each other) but all connected under the same switch
I would need to connect them like he did, all wired, but all under the same switch. I tried to do this, but they connect to each other via wifi even if they are connected to the switch
Hi @Andrea94
Please install the satellite with wireless backhaul at first and after completing the installation, then put the satellite under the switch.If your Multy is far away between each other, you have the option to set up separate sites for each Multy device. You can then configure these Multy sites with the same SSID and password.
- 435 Beta Program
- 176 Nebula Ideas
- 428 USG FLEX H Series
- 298 Security Ideas
- 79 Switch Ideas
- 274 Service & License
- 422 News and Release
- 89 Security Highlight
