Nebula didnt show the application of use of my device connected to the AP
Hello Support
Good day!,
I have a simple question
This is the topology
Internet —> AP(NWA90AX)
I connect my phone and laptop in AP via WiFi my question is "why i cannot see the client device, usage, application being access by laptop and phone in Nebula"
I'm using Nebula Base Pack.
Thanks for your usual support
Hi @mluy ,
It appears that your site is currently in Saving mode, which causes Nebula to not monitor most network activities. Please disable Saving mode and then check if the information becomes visible on your site. To know more about that, please refer to this FAQ .
Note that: the screenshots you've mentioned pertain to the Application Usage feature, which is included with the CNP/CNP+ license. However, as of now, your NWA90AX is not compatible with this license and does not support the feature. For more information about Application Usage, please consult the provided FAQ:
If the issue still recurs after disabling the Saving mode, please enable Zyxel support by navigating to 'Help' at the top right corner of the page, selecting 'Support Request', and then enable 'Zyxel Support Access' and Click Save.
Zyxel_Judy
Hi @mluy ,
Zyxel_Judy
- 438 Beta Program
- 188 Nebula Ideas
- 6.2K Security
- 454 USG FLEX H Series
- 303 Security Ideas
- 81 Switch Ideas
- 278 Service & License
- 435 News and Release
- 91 Security Highlight
