ZYXEL FWA510 wifi settings page not loading
Hi Kay,
I have also upgraded the firmware and didnt need to check the "Restore Default Settings After Firmware Upgrade" checkbox. The upgrade went really well and all of my settings were retained. I can also see all of the other pages without any problems.
Thanks for resolving this issue!
Best Wishes.
Hi Kay
I have the same problem also with Nebula FWA510. I can't find the datecode firmware under download library. How can i get it? Mauby you would add to library?
Hi @Zyxel_Kay , I have the same problem, could you sent to me the "patch / firmware"
Regards
I've just bought one of these routers and am eagerly looking forward to getting it in a week's time.
I guess the general message is don't upgrade to FWA510_1.17(ACGD.0)C0 until the fix is posted? I normally upgrade everything as soon as I get it, so this is a bit different. I hope it doesn't auto update.
Any idea when the fix is going to be posted?
It sounds like it might be a good idea removing the broken firmware from the downloads page until it is fixed?
Hi Kay
Tanks for the firmware datecode.
Now it works :-)
Regards
My problem accured when i installed and setup nebula-app. So dont do that:-)
Hi @bejb,
We are temporarily removing the broken firmware from our servers. Our team is actively working on an updated version soon.
For questions, please feel free to leave your comments.
Regards
- 415 Beta Program
- 2.4K Nebula
- 145 Nebula Ideas
- 96 Nebula Status and Incidents
- 5.6K Security
- 240 USG FLEX H Series
- 268 Security Ideas
- 1.4K Switch
- 71 Switch Ideas
- 1.1K Wireless
- 40 Wireless Ideas
- 6.3K Consumer Product
- 247 Service & License
- 386 News and Release
- 83 Security Advisories
- 28 Education Center
- 9 [Campaign] Zyxel Network Detective
- 3.2K FAQ
- 72 Security Highlight
