GS1920-24HPv2 DHCP IP ranges - auto logout (time)
Hubbi
Hubbi Posts: 7 image  Freshman Member
i´ve 2 questions regarding the mentioned switch.
  1. It is possible to increase the time until automatic logout?
    it's annoying sometimes, when you have a look into the guide, YouTube or something other, and after a few seconds you have to login again. :-(
  2. my Setup is FritzBox (Fibre Router) → GS1920-24HPv2 → AP NW-1123-AC-PRO
    currently my FritzBox is the DHCP server. I would like to have DHCP server which can provide different IP-ranges for different VLANS:
    i.e VLAN 10 (my own devices) IP: 192.168.10.1 - 192.168.10.255
    VLAN 20 (guests) IP: 192.168.20.1 - 192.168.20.255
    Is this configurable with the GS1920-24HPv2 switch?
btw: currently i use the standalone - on Premise version.
regards
Hubbi
  • Zyxel_Melen
    Zyxel_Melen Posts: 4,593 image  Zyxel Employee
    Hi @Hubbi,
    Yes, you can increase the time of timeout. Please refer to this FAQ:
    In addition, you can also use HTTPS protocol to access your switch web GUI.
    Yes, you can configure VLANs on GS1920-24HPv2. Please refer to this FAQ for configure VLAN setting:
    Your configuration would be like the below example:
    Topology
    FritzBox —— (port 24) GS1920-24HPv2 (port 1 for VLAN 10 and port 2 for VLAN 20) —— PC and another device
    Configuration
    VLAN 10:
    VLAN 20:
    VLAN port setting:
    Hope it helps.
    Zyxel Melen
  • Hubbi
    much thanks for your explanation, but my goals is to set up two VLANS. One internal WLAN (my own) devices, and one Guest WLAN over teh AP NW.1123_AC-PRO (described in
    My question would be, it is possible to configure the GS1920 so, that it works as a DHCP server and whether I can provide different IP ranges for the VLANS.
    like:
    - VLAN 10 (my own devices) IP: 192.168.10.1 - 192.168.10.255
    - VLAN 20 (guests) IP: 192.168.20.1 - 192.168.20.255
    Or do I have to do this via a corresponding router?
    btw.: The FitzBox cannot use VLAN
    I'm sorry for the strange questions, but I've only recently started working with VLANS and Zyxel devices
  • Zyxel_Melen
    Hi @Hubbi,
    Thanks for the information about your FitzBox.
    To fulfill your purpose, It is not only to set VLANs on the switch but also to create VLAN interfaces on the router. In other words, the router has to support the VLAN interfaces.
    I recommended purchasing a router/firewall that supports the VLAN interfaces.
    In addition, GS1920 is a layer two switch. It does not support the DHCP server function.
    Zyxel Melen
