Smarthome use GS1900-24E = Impossible .... 😤
124»
    PeterUK Posts: 3,740  Guru Member
    I did say don't connect anything to the switch other then your PC with a fixed IP of 192.168.1.2 as in don't connect Starlink don't connect switch to internet then connect to 192.168.1.1
    Peter ….. you might have attitude problem that isn't good
    sorry you feel that way😓
  • Zyxel_Melen
    Zyxel_Melen Posts: 3,176  Zyxel Employee
    Hi @QTT1,
    Have you followed the guide I provided previously? Are there any problems that need help after you follow the guide?
    Zyxel Melen
  • QTT1
    QTT1 Posts: 25  Freshman Member
    Back home again …. still no with wifi or with out those addresses cant be accesed …
    Only the computer:
    12th Gen Intel(R) Core(TM) i5-12400F 2.50 GHz
    64-bit, x64-suoritin
    Windows 11 Home version 23H2
    and your device connected via ethernet cabel…..
    Please advise?
  • Zyxel_Melen
    Hi @QTT1,
    To help you solve this issue, could you provide a remote for me to check? Please provide me with the AnyDesk ID, AnyDesk access password with full privilege, and the Windows PC's password (if it needs a password to log in) for the remote. I will access it to help you find the GS1900 and check.
    Zyxel Melen
  • QTT1
    Hi Melen,
    Ok thanks finaly.
    what’s your business hours ?
  • Zyxel_Melen
    Hi @QTT1,
    I have sent the information to you via the private message. Please check it.
    Zyxel Melen
  • QTT1
    Morning,
    where did you sent it ?
  • Zyxel_Melen
    edited December 2023
    Hi @QTT1
    Please check this link to find the private message. Thanks.
    Zyxel Melen
  • Zyxel_Melen
    Hi @QTT1,
    After remote, I have helped you to make sure your GS1900 is working with your smart hubs. Please keep monitoring if there are any problems. Happy new year to you and your family!
    Zyxel Melen
