NR7101 vs iphone 5g speed
13»
  • n_o
    n_o Posts: 68 image  Ally Member
    755 and 156510  is MCC 2 = vodafon
    i have telekom = MCC 1
  • BrandSafway
    BrandSafway Posts: 22 image  Freshman Member
    I noticed this at one of my locations as well.
    A co-worker has the latest iPhone connected to 5G and can reach 500mbit down on the roof next to the Zyxel NR701 using the same provider with 5G. While the Zyxel is connected to the same cell, it can only reach 100mbit down. I suspect QOS on the carrier side or that the iPhone is doing dual carrier and the Zyxel can't with the current firmware module.
    What is the advantage of setting "PS only" over "combined"?
    btw i have 8 Zyxel NR7101 currently running on 8 different sites across different carriers and they all run stable with the latest available device and modem firmware module. can't wait to test zyxels update for dual carrier firmware.
  • SELBERG
    SELBERG Posts: 373 image  Master Member
    5 Answers First Comment Friend Collector Fourth Anniversary
    100M, not a LAN problem?
    I had that problem due to a faulty ethernet cable.
    Changed it and now i have 1000M/Full.
  • BrandSafway
    I was actually on site the other day and was able to confirm that the LAN connection on the router was showing 1000M/Full. We did another test with the employee's iPhone. It easily reached 500mbit next to the Zyxel. I suspect either ISP QOS based on IMEI or carrier aggregation on the iPhone.
  • benmaxky
    benmaxky Posts: 2 image  Freshman Member
    Your comparison is necessary because it will help companies improve high speed for users. Sonnries123
  • emreoez
    emreoez Posts: 23 image  Freshman Member
    how does this ended up for you? I'm having the same problem. Also Germany and Telekom.
    I'm not able to force the router to 5G. On auto everything works well but only around 3-400mbit dl / 120mbit ul.
    Forcing it down to NR5G-SA ends up without internet connection at all, filling up the cellular lock 5g field manually with the information from the PCI scan ends up also without internet.
