Sync stops suddenly - DropBox Zyxel NAS542
Hey,
I've got a Zyxel NAS542, and I want to transfer all NAS data to a DropBox account.
I'm able to set up the DropBoxClient app in the NAS, and the synchronization kicks off well (I monitor it using PuTTY with the command tail -f PATH/.dropbox.log file).
But, out of the blue, sync stops randomly and I see this message on PuTTY:
[DATE][INFO] Start to run ZyDropbox
[DATE][ERROR] Invalid access token
Seems authorization/validation token is missed at some point during the sync (don't know why), but when this happens sync stops…
Does anybody know how to solve this problem? I'm getting frustrated honestly after several attempts…
Information:
DropBoxClient version 10.10.0zypkg003
Firmware: V5.21(ABAG.11)
Thanks in advance,
Best regards
It used to work four or five years ago, but I don't count that period. After they changed or updated the server, it's no longer available in the business account. Every company may need to promote its own product la.
Are you using the advanced Dropbox account, or are you using the free account?
From what I understand, Dropbox has implemented some enhancements for the advanced account, and currently, it may support the free account. In my house, it works perfectly with the free account.
Hey,
Thanks for your response!
It's a Business Dropbox account.
Could that be the reason? Because it's so, that's odd…
Best regards
Hey,
Thanks for your response.
There's nothing I can do then… I'll find an alternative solution.
Best regards
- 3K Nebula
- 222 Nebula Ideas
- 619 USG FLEX H Series
- 349 Security Ideas
- 53 Wireless Ideas
- 485 News and Release
