NAS542 - Teardown video/instructions?
Does anyone have instruction (or video) of how to open NAS542 entirely?
(Didn't find anything on Youtube or via Google search… 😐️)
I just realized how much dust it has collected inside the chassis and thought that a proper cleaning might keep the temp down a bit at least…
In the past have opened both a 326 and a 540. In both cases it's basically removing every visible screw, and splitting the housing on two seams. As far as I remember the seams on the 540 were harder than the seams on the 326. The latter could be opened with some careful prying. On the 540 I needed a table knife to pry open the clips on the inside, while the steel frame was still inside.
I've found some helpful videos that might assist you. However, I couldn't find a disassembly guide specifically for the Zyxel 540.
OK, thanks for answers!
I'm going to give it a try as the box looks like it needs a thorough cleaning… ;-)0
- 415 Beta Program
- 2.5K Nebula
- 152 Nebula Ideas
- 101 Nebula Status and Incidents
- 5.8K Security
- 296 USG FLEX H Series
- 281 Security Ideas
- 1.5K Switch
- 77 Switch Ideas
- 1.1K Wireless
- 42 Wireless Ideas
- 6.5K Consumer Product
- 254 Service & License
- 396 News and Release
- 85 Security Advisories
- 29 Education Center
- 3.6K FAQ
- 76 Security Highlight
