Upgrade LTE Module LTE5398-M904 from USB - possible?
TurtlePL
It's doable? I don't have RJ45 on my MBA
Yes, you can upgrade LTE Module LTE5398-M904 from USB
Hi @TurtlePL
Welcome to the forum.
According to the user guide at https://download.zyxel.com/LTE5398-M904/user_guide/LTE5398-M904_EU_1.00_2.00%20Ed2.pdf I do not think that it is possible to upgrade via USB.
I think that you could try to get a USB to Ethernet adapter, so that you can connect by Ethernet.
Or you could try to connect by WiFi to do the upgrade.
The upgrade software files are at https://www.zyxel.com/global/en/support/download?model=lte5398-m904
Kind regards,
Tony
- 601 USG FLEX H Series
- 480 News and Release
